Trigger Configuration Mercedes M104.941
Posted: Thu Jul 28, 2016 1:25 am
by pric
i have a M104.941 (inline 6, std firing order 1-5-3-6-2-4).
I equipped it with a flywheel from a later model which has a 60-2 pattern on it. (instead of VDO 3plates with permmanent magnet)
The engine uses VR sensors for both, cam and crank.
However if i turn the engine in TDC the cranksensor is reading tooth number 10.
So i choose tooth number 0 for "first trigger tooth", so i have 11 teeth or approximately 60° between those two.
Is this alright?
The Engine does sync and fires up for a short time, but stalls then .
I tried playing around with trigger edges, and starting fuel dose and so on but i cant get it to idle.
Using a timing light when starting, to see if the trigger angle is right is tricky because of the wasted spark ignition... (two arcs in short time)
Any Tips?
greetings
Re: Trigger Configuration Mercedes M104.941
Posted: Fri Jul 29, 2016 10:30 am
by Kisielisodd
Post Your log file from cranking and fire up attempts or just send it to tech@ecumaster.com
Posted: Fri Jul 29, 2016 8:26 pm
by pric
Thanks for your Support!
Also the Engine is synchronising in no time, so that should not be the issue.
Posted: Mon Aug 01, 2016 10:07 pm
by pric
Engine fired up today and it's running!
https://www.youtube.com/watch?v=eGrWPkneDXg
Those are my Settings:
Timing is perfect with Trigger Tooth 0 and Trigger Angle of 61°.
The Problem was, it wasn't getting enough Fuel after starting.
I had to write in at least 50% in the VE table in low RPM range and "no" load, is this normal?
I'm using stock 190cc Injectors at the Moment, because one of my 440cc was leaking permanently.
Greetings
