Hi
Could someone confirm that when using gearcut function with an active low analog input the cut function will remain active for the duration of the signal regardless of time settings.
This is due to using an external gearbox control unit that requires the EMU to perform torque reduction in response to its signal.
Gearcut duration
Re: Gearcut duration
Yes analogue is designed for external controller and duration is "while signal active"
When you select analog input to control gear cut you can select what analog state will cause gear cut (active low or active high)
many thanks
that will do nicely
that will do nicely
