Oxygen Sensor LSU 4.2 shows only 1
Posted: Mon Aug 08, 2016 4:33 pm
by dontriple
i have a problem since 2-3 Months with my second EMU,
AFR/Lambda shows only 1
ive checked 100 times the wiring, changed the Laptop, changed the LSU :(
Can u help me maybe? it has never been shown something else than 1 :(
my other EMU works perfect :)
Re: Oxygen Sensor LSU 4.2 shows only 1
Posted: Thu Aug 11, 2016 5:43 pm
by dontriple
Please help :) Where are the EcuMaster Gurus
Posted: Sat Aug 13, 2016 5:44 am
you can try swapping your ECU's ... but it can only be a wiring or a sensor problem
Posted: Thu Sep 01, 2016 10:14 am
by dontriple
we swapped yesterday the ECU and it still shows Lambda 1 / Ive transfered also the ECU Files from my working ECU to the other and no chance :(
Lambda shows still only 1 ..... Please guys give me a last hope :P
Posted: Thu Sep 01, 2016 6:14 pm
by pric
Must be something with the wiring.
Maybe no supply on the Sensor?
Posted: Thu Sep 01, 2016 7:24 pm
by dontriple
But i swapped the ecu and than it works, i have 2 cars running on emu. And the one is not working since ive bought it
Posted: Thu Sep 01, 2016 10:15 pm
by PSI-Motor
dontriple wrote:But i swapped the ecu and than it works, i have 2 cars running on emu. And the one is not working since ive bought it
Send it to your reseller and he will fix it.
Posted: Fri Sep 02, 2016 8:08 am
by dontriple
OK, than i will send it to the reseller in some weeks because i need the car :)
One last hope:
1. Are the Outputs/Inputs for the LSU 4.2 one the ECU fix ? Or can i change them?
2. on my Log all values are moving except of the AFR/Lambda, my this help :)
Posted: Mon Sep 12, 2016 11:01 am
by dontriple
:roll:
Posted: Mon Sep 12, 2016 11:51 am
by Kisielisodd
1) wiring problem
2) power supply issue
3) damage sensor
No readings at all from the sensor.
Posted: Mon Sep 12, 2016 12:22 pm
by dontriple
1) Wiring problem it can not be, because it works with my other EMU
2) Sensor problem, the same
3) Power Supy, the same
IT must be something with the EMU / U know mybe how i can check this ?
Posted: Mon Sep 12, 2016 1:25 pm
by Kisielisodd
dontriple wrote:Hi,
So finally is lambda working on other ECU or not ?
Posted: Mon Sep 12, 2016 1:31 pm
by dontriple
Yes it works on other EMU /
Posted: Mon Sep 12, 2016 1:33 pm
by dontriple
I meant that i swapped the "BAD EMU" to my other car, where everything is working perfect.
And it still dont work
So it must be something "INSIDE" the EMU :/
Posted: Mon Sep 12, 2016 4:51 pm
by Kisielisodd
Ok understand, there may be a internal malfunction, the only way to confirm damage unit, is to send it back.
Posted: Tue Sep 13, 2016 9:15 am
by dontriple
Ok than i will send it back in 1-2 Months,
but mybe can u give ma tipp how i can read mybe in a other way the Lambda ?
Which of this values will show me the Lambda in Volt ?? Or will my plan not work :D
