Adjust Ignition Timing
Posted: Sun Aug 21, 2016 9:48 am
by Black_Supra
How can i set up the correct ignition timing?
Where i can find that function? I used a ignition light to read timing and there is a missmatch of around 10 degree (2JZ GTE VVTI)
This engine got no mechanical option to adjust timing like the CA18det - i think i have to do this in emu software.
Re: Adjust Ignition Timing
Posted: Sun Aug 21, 2016 10:51 am
by Karel
Did you read manual ?
Posted: Sun Aug 21, 2016 12:31 pm
by Black_Supra
Yeah i did,
i changed the "first trigger tooth" value because this should be responsible for the first ignition but - no results
seems like this is wrong - should i work with the trigger angle ?
Posted: Sun Aug 21, 2016 5:08 pm
by Sm887
Yes change the trigger angle till it matches.
Send me your map so i can take a look at it. Or post all of your ignition settings.
Also, make sure you have the right polarity on your crank/cam sensors.
Posted: Sun Aug 21, 2016 6:19 pm
by Black_Supra
I did it now with
Ignition - Ignition event trims
First cylinder needed 8.5 degree to match with the timing light, i applied the 8.5 degrees now to all 6 cyl - should work right ?
Posted: Mon Aug 22, 2016 10:06 am
by Kisielisodd
it will work, this way, but it is a workaround. Two options are responsible for correct timing adjustments.
Trigger tooth, which is a "coarse" trigger adjustment
Trigger Angle, which is a fine trigger adjustment
8 degrees misalignment can be set in trigger angle, to match perfectly.
