help tachometer golf 2
Is there anyone who has installed Emumaster on a golf 2 and got tachometer and work? original so tachometer connected to the ignition coil. I have attached the cable to Aux 4 which then goes to pin 10 on the (T28) connector behind the dashboard
Re: help tachometer golf 2
There is an issue with getting these working with a Megasquirt, I assume the EMU will be the same
http://www.clubgti.com/showthread.php?2 ... ounter-fix
- Kisielisodd
- ECUMASTER TEAM
viewtopic.php?f=19&t=852
i don't know the issue with speedometer, but maybe similar solution to this, will solve problem
I installed it in an MK2 with this module http://www.zmm-electronic.de/ignition-s ... anguage=en
It worked very well.
Do you drive Wested spark or singel coil ? or use the module with Emu master ?
I forgot to write that I have a VR6 engine in a Golf 2
Try to pullup AUX4 output with the coil from relay
It will induce high voltage. In most cases tacho driven by ignition coil works correctly
need for additional protection aux output of high voltage from the coil as you advise ?
I test with the relay tomorrow
It works now ☺ . One Bosch bip373 conected on AUX4 then a relay coil to . Thanks for the help
Did you try without BIP ? It also should work
I have tried without bip and another auxiliary . Did not work
