camsync/camsensor issues BMW M52
Posted: Sat Dec 05, 2015 3:57 pm
Hey, i have a massive problem regarding my camsensor and camsync. It's a M52B28 BMW engine, completely original. The crank and camsensors should both be Hall sensors. And i have once the original wiring loom with original ecu installed on the car, and a seperate wiring loom with the ecumaster ecu. So i simply can switch between original ecu and ecumaster by changing the sensor plugs. (The car is doing its job as normal with original ecu).
First of all, i have a picture attached once with the crankshaft and once with the camshaft sensor. It shows the connection plugs to each sensor (+ - and ground). I have measuered both sensors to check volt and ground connection. So as you can see in the pic the crank sensor is fine, 5 Volt from "+" to "g" and from "-" to "g", and the ground connection is really connected to the ground (i have measured the resistance between "g" and the engine block and the result was 0 ohm)
So if you have a look at the cam sensor now it becomes all little bit tricky. I only can measure 2.5V (shouldn't it be 5V?????) between "-" and "g" connection in the camshaft connector plug. And if i measure the resistance between "g" and the engine block, the resistance is infinitely high (if i compare to crank sensor, it should be 0 ohm, what would make sense to me). But there is 0 ohm resistance between the "-" connector and the engine block. What the fuck is goin on here? If i compare with the crank sensor, it's all really messed up, all completely different but both are hall sensors. Or is the cam sensor anything special like no hall and no vr? Anyone here who has the M52 Engine running with ecumaster (M50 Engine have different sensors).
I measuered all these values with the original ecu connected, because car is running fine in original condition.
If i connect the ecumaster now, crank is exactly the same. But ecumaster powers up the cam sensor with 5v between "+" and "g" and between "-" and "g" (same like crank). So the reslult is i have no cam signal. (You can see it in the second pic, there is a scope).
I would say ecumaster is doing its job right, but does anyone know whats the problem with the cam sensor, or how to connect the cam sensor? I am about to getting crazy with this sensor, i tried to figure out the problem for 4 days now but i have no clue where's the problem.
And because of that missing camsync i never made the engine running.
