1jz ecu setup
Santi253
1jz ecu setup
Post by Santi253 » Mon Dec 14, 2015 11:06 am
having trouble with my emu and getting setup
says inactive
injector and coil phase
153624 in that order for both
iacv not hooked up
550cc denso injectors
can someone help me setup a base map for this thing :D
Re: 1jz ecu setup
Post by RHD » Mon Dec 14, 2015 3:21 pm
you will need to adapt it to suit your wiring but these settings do work
1JZ_start.emu.emu
(74.02KiB)Downloaded 94 times
Scooter
Re: 1jz ecu setup
Post by Scooter » Tue Dec 15, 2015 3:22 am
This is the ignition outputs and injector outputs I'm using, set at 10deg BTDC too. Your setup will depend on what coil setup you are running too, so check the coil wizard. here is a map with oem VVTI coils, set as wasted spark
1jz_14DEC15.emu
(96.38KiB)Downloaded 71 times
tommyboyblitz
Re: 1jz ecu setup
Post by tommyboyblitz » Wed Dec 16, 2015 1:14 am
RHD wrote:you will need to adapt it to suit your wiring but these settings do work
Im using this map and seems to be working well. The other one was very rich.
Im running 1jz gte vvti no vvti yet or a proper tune, but is working well and very smooth.
5-12-2015.emu
(95.31KiB)Downloaded 98 times
Santi253
Re: 1jz ecu setup
Post by Santi253 » Wed Dec 16, 2015 4:01 am
got my jz to run and idle
seems like the ignition and coil pack order was wrong,
i had it set 153624 life the firing order and some timing settings were wrong
thanks for the help :D
