boost target in log way too high
aaronRX72JZ
Post by aaronRX72JZ » Sat Aug 27, 2016 8:09 am
i have my boost target set to 250kpa across the table but in my log it says it is set to 375 kpa so when i use my boost controller it doesn't open the waste gate had a nasty 280 kpa spike! please need help.
boost log
Tomek_P
Re: boost target in log way too high
Post by Tomek_P » Sat Aug 27, 2016 11:03 am
aaronRX72JZ wrote:i have my boost target set to 250kpa across the table but in my log it says it is set to 375 kpa
You have boost correction 150% ( 250 kPa *1,5 = 375 kPa )
Check GEAR SCALE, VSS SCALE, IAT SCALE, EGT SCALE.
BMW e30 M50B25 +turbo
aaronRX72JZ
Post by aaronRX72JZ » Sat Aug 27, 2016 4:36 pm
i found it. it was the EGT table. thank you for the help.
