Problems with trigger Setup M50 with M52 Trigger Wheel
Hello ,
I hope that everyone can help me,
I build a M50 NV Turbo an have Logic Problems with the trigger Setup.
The M52 Wheel have the 2 missing tooth 324deg After TDC
But what i have to tipe in the EMU ?
I have tip in
From top toll Bottom in the trigger Setup
- VR Sensor
- Enable Pullup yes
- 2 missing teeth
- Falling
- 6
-60
-3
-60
But no Start.
Sorry for the idiotic question But my English ist mit so good. With ne old MS2 i can put the 324 in.
Thanks for help
I have tip in
- VR Sensor
- Enable Pullup yes
- 2 missing teeth
- Falling
- 6
-60
-3
-60
But no Start.
Thanks for help
Re: Problems with trigger Setup M50 with M52 Trigger Wheel
First trigger tooth 45
Trigger angle 54
Trigger angle 54
Thanks a lot.
I Hope it will Starts tomorrow, the Rest Is all corectly configured.
Best regarts.
Best regarts.
Can you take a look over my basemap?
I test it all, but it is not starting
M50B28 NV complete build up for Turbo.
only m52 part is the trigger wheel and the crankshaft.
its only a map to start, an rolling with max 2500rpm for check all the motor parts and looking for leaks.
- M50 Startmap .emu
- (78.05KiB)Downloaded 90 times
And i use VAG RED 115 Coils
Send cranking log.
For my cranking fuel is too high, try 4-5ms
BMW e30 M50B25 +turbo
- Kisielisodd
- ECUMASTER TEAM
Try for beginning set coils to fire in pairs.
Event 1 - 1+6
Event 2 - 5+2
Event 3 - 3+4
Event 4 - 1+6
Event 5 - 5+2
Event 6 - 3+4
If engine will start, set VE map for idling, corrections for warm up enrichment, injector pulse for cranking, and then change ignition to full sequential.
Event 1 - 1+6
Event 2 - 5+2
Event 3 - 3+4
Event 4 - 1+6
Event 5 - 5+2
Event 6 - 3+4
But for Dual fire i must connect the Coils in other configuration, or can i configured it in the EMU?
I only see cyl 1+2, 3+4, 5+6 not the pair 1+6 5+2 etc.
I despair
I despair
Download and upgrade to latest software and firmware.
for VR sensor enable pullup should be NO!
