XuMuK - Posts:14
EMU Support of BMW M70 Camshaft VR-Sensor
Post
by XuMuK » Sat Sep 10, 2016 9:43 pm
Hello @all,
does EMU support this kind of BWM Camshaft-Sensor, used on M20,M30 an M70 Engines:
It is mounted on the ignition cable of the Cylinder 6, Figure Nr. 9 at the Picture above
WHPZach - Posts:184
Post
by WHPZach » Tue Sep 13, 2016 5:02 pm
I would make every effort to install a normal VR or Hall effect sensor using a trigger wheel off the crank and cam.
- Site Admin
Post
by Jadzwin » Tue Sep 13, 2016 5:31 pm
If I good rememember it works as an indicator of first cylinder.
But use is a little tricky, you need to enable engine start without sync
XuMuK - Posts:14
Post
by XuMuK » Wed Sep 14, 2016 1:58 pm
Jadzwin wrote:If I good rememember it works as an indicator of first cylinder.
Yes, that ie right!
Jadzwin wrote:But use is a little tricky, you need to enable engine start without sync
Is that possible with last EMU-Firmware, i think no, because i didn´t find this option at ignition settings?...
