EMU Serial logger
Hi
Is it possible to use the Ecumaster serial logger at the same time as the bluetooth adaptor.
thanks
Chris
thanks
Chris
Re: EMU Serial logger
EMU serial logger has built in BT module
Two for the price of one
Fantastic work as usual
thanks
thanks
Where can I find out more about the serial logger?
Please contact our sales department sales(at)ecumaster.com
Hi
i have a problem with the logger where i have just the green led for ready to work illuminated all of the time
no data is being recorded and no blue flash from led when i set date and time ( i have latest firmware) also no bluetooth communication.
Any ide what the problem could be.
thanks
Chris
thanks
Chris
You have reversed rx and tx ?
Hi jakub
Thanks for the information
i have swapped tx and rx over when i click set date and time led goes blue but with red double flash, i have tried several SD cards all with same result.
Is there a particular format needed for the card ?
Bluetooth function works correctly but led is red not blue ?
thanks
chris
thanks
chris
You have previous version of logger with red LED for BT and two colour diode for status.
So probably you have also old firmware that supports only EMU BLACK.
Use SDHC card 4GB or bigger with FAT32 (default file system).
Copy firmware file into root directory.
There will be visual indication on status diode when firmware upgrades.
Firmware 1.02
https://dl.dropboxusercontent.com/u/286 ... RE1_02.zip
Firmware 1.02
Hi Jakub
i will give this a try and let you know
Chris
Chris
Hi Jakub
all sorted and working now, for some reason had to use a brand new card with firmware update before it would work ?
many thanks for your help
Chris
Chris
What was the card that didn't work ?
Jadzwin wrote:What was the card that didn't work ?
Sandisk Ultra 8GB / class 10 30MB/s
Card had previously been used in other applications but formatted before use
Chris
