Problems with latest clients on windows vista 32bits
Omibi
Post by Omibi » Sat Dec 26, 2015 6:36 pm
I'm having problems with the latest clients on windows vista 32. I was working with client 1.151exp1 and everything was ok. But when I tried the 1.157exp1 and later 1.158exp1, even if the installation seems to perform ok when you try to run the client the application is not opening. Looking at the process administrator you can see that three processes are created (EMU.EXE) but the application is not starting.
Swift turbo
Re: Problems with latest clients on windows vista 32bits
Post by Swift turbo » Sat Dec 26, 2015 7:57 pm
Hi.I had the same problem..if I right clicked and ran as administrator and also I have avg antivirus and must run the application in a "sandbox" .the client app then opens but I still have a problem with open gl in my onboard graphics..its looking like I need a new computer.. Stay away from toshibes and Intel HD graphics.Good luck
Omibi
Post by Omibi » Sun Dec 27, 2015 10:04 am
I stopped the antivirus (avast in my case), run the installer as administrator and now works fine. I uninstalled again to try to figure out which was the right solution but now I can install it even if I have the antivirus working and I run the installer without administrator right. I guess some change was made, in the registry I suppose, that remains even if I uninstall the program. ATI graphics in my computer.
