Starting problems
Posted: Wed Sep 28, 2016 9:26 pm
I've just wired up an Audi 2.7t but i'm having problems getting it started. I picked up a couple of basemaps from others but they both had the firing order wrong. 1-3-4-2-6-5 on one and 1-3-4-6-2-5 both with an output offset of 3. The firing order is 1-4-3-6-2-5 with 0 output offset.
I've managed to get it started a few times but it cuts out after a few seconds usually (did get it to run for about a minute once with the revs pulsing up and down from 400-700rpm). I'm not having any consistency, i'm finding adjusting the cranking fuel table is not getting me the desired results either. I can go right from 0 to 20 m/s without so much as a cough or splutter from the engine, the fuel is getting in, I can smell it. The injectors are Bosch 750cc EV14
I'm thinking I must either have setting well off somewhere.
Any tips on what I can do to narrow down the problem?
