i was wondering ,if anyone else is experiencing this phenomenon. Sometimes, mostly when the intake is still cold, but engine is already at operating temperature i am experiencing a large spike under the knock voltage, when going off throttle. This happens only, if the car was under boost before letting off. This rarely, almost never happen ,when the intake is already hot, like the car was drivenfor around 20+ min. I have not tested, while the car is cold for obvious reasons
P.S. Forgot to mention. Car is toyota SW20 with 3SGTE gen2, Wiseco pistons a bit of slap from them, when cold, around 9.3:1 compression, boost is ~1.2bar, using the stock narrow band sensor. Settings for sensor are 6.64khz, 1.06 Gain, 100 Integrator. AFR under boost is rich ~11-11.5:1
