Cam variator setup
Laurysr
Cam variator setup
Post by Laurysr » Sun Dec 27, 2015 11:24 pm
Hi , im trying to setup inlet cam variator
origialy its activated up to 3000rpm after that it deactivates.
its activated by signal to relay and its on/off type
Inlet cam timing with variator off - opens at 8deg after TDC , closes at 54deg ABDC.
with variator on - opens at 10deg BTDC , closes 36deg ABDC.
how shall I set it up (vvti control wont work as it sends frequencies rather than fixed on / off? )
and in theory it will allow to advance timing by extra 18deg?
Thank you
Re: Cam variator setup
Post by PSI-Motor » Mon Dec 28, 2015 1:27 am
Wich motor? Use parameter output.
Laurysr
Post by Laurysr » Mon Dec 28, 2015 5:06 pm
Ifs a fiat coupe 5cylinder 20v turbo lump.
So u are saying i should use different output ?(not from vvt control section)
In that case do I need to change ignition timing accordingly or just set it as original to be open up to 3k rpm?
Post by Jadzwin » Wed Dec 30, 2015 1:07 am
Use parametric output or VTEC configuration from VVTi parameters.
