Lets share Lambda/AFR target tables
Posted: Tue Oct 18, 2016 9:52 am
Hi everyone,
As the first step in advanced fueling strategy and the new autotune option is setting up a Lambda/AFR target table, I thought it would be a good idea to share our tables together with info about the engine/mods so we can learn from each other and setup a base table which gives you a relative safe starting point.
Some info about AFR numbers with thanks to Clem:
Download link .emut file
https://www.dropbox.com/s/a2nld2qxcgh50 ... .emut?dl=0
My engine:
VW 1.8L 8V
T28 turbo
550CC injectors
270 degree cam
Group fire injection, distributor for spark.
For my first attempt I kept the numbers relative low to be on the safe side as no tuning has been done yet.clem wrote: AFR Target table should be tuned accordingly to VE and EGT. Higher VE means higher cylinder pressure and therefore higher combustion chamber Temperature. Higher gas temperatures in the compression stroke give a higher tendency to abnormal combustion (Knock in best case, Pre Ignition in worst case). To give you an idea:
Knock: Ignition happens beginnning with the spark and great amounts of gas burn immediately, therefore creating great amounts of heat -> melted pistons.
Knock happens tendencially in low engine speed and high load conditions. At higher RPMs (>5000) there is not enough time to develop a detonation.
can be avoided with: retarded Ignition angle, lower charge temperature, lower compression ratio, fewer hot rest-gases from last combustion, good homogenized charge, well designed combustion chamber without hotspots.
Pre-Ignition: Ignition happens in the compression stroke before the spark occurs, again much gas burns immediately. The damaging cause here is the extremely high cylinder pressure -> broken pistons/conrods, bent conrods. Pre ignition can be experienced in all engine speed ranges, at high loads. The pre igniting cylinder(s) would run in "diesel-mode" into self destruction within a hand full of cycles, if not the fuel injection is shut off after the first event.
can be avoided with: lower charge temperature, good homogenized charge, lower compression ratio, well designed combustion chamber without hotspots.
Only add fuel (lambda < 1) if there is danger of abnormal combustion or your EGT is too high for your turbo or your catalytic converter.
At lambda ~ 0,9 you could get the most power out of your charge. At lambda ~1,1 you could get the most power per fuel out of your charge.
With these very generic rules you should be able to create your own Target AFR table. VE, IGN, AFR, BOOST, have to be tuned to work together for one specific engine setup.
Compare Maps from different engines with different mods could mislead you if you do not 100% know what you are doing. Try to give your setup what it needs and have fun with that vastly big puzzle![]()
Start at low engine speeds and loads, where you can hardly ruin a thing, to get a feeling for tuning an ECU.
Clem
My engine:
VW 1.8L 8V
T28 turbo
550CC injectors
270 degree cam
