FJO external wideband; how do i enter non-linear afr/volts?
Posted: Sun Oct 23, 2016 5:07 am
I have my fjo wideband controller installed and connected to the EMU.
in the Oxygen sensor menu, I have external controller selected. I can enter the AFR at 0v and 5v, which works for linear responding sensors. but the NTK in the FJO is non linear so I can have it be more accurate in the middle of the range and less at rich/lean.
or I can make it more accurate at the rich/lean ends of the voltages but less accurate in the middle of the range.
Is there a way I can manually specify the voltage to AFR conversion table? not just the 0v and 5v ends?
