Pc Connection fail after engine start and revin
Posted: Sat Oct 29, 2016 12:03 am
by Kenny123
Well my problem is maybe simple ...
Car is running ok and the tune get to a good level !
But when I connect my laptop to the emu my connection get lost after starting the car and get the rpms a little higher
Anybody else got these problems ?!?
2jzgte 3,4l stroker Single Turbo
1300id injectors
My connectors are directly fitted to the loom
So no adapter !
Maybe a problem with ground or something !!???
Any idea would help ;)
Thanks a lot Kenny
Re: Pc Connection fail after engine start and revin
Posted: Sat Oct 29, 2016 11:40 am
by gips
Are you using the laptop on charger connected to the car cigarette lighter ?
Posted: Sat Oct 29, 2016 6:07 pm
by Kenny123
No in battery mode
Allready try a laptop of a friend which was at the tube on his Supra ! Same problem !
Posted: Sat Oct 29, 2016 7:37 pm
It could be caused by wrong grounding or broken USB cable
Posted: Sun Oct 30, 2016 11:22 am
by Kenny123
Well I would check it !!!!
I use the oem 2jz loom and strip it out ....
maybe should I ground the emu separately direkt to chassi ground ? ?
Posted: Tue Nov 01, 2016 3:15 pm
by Kenny123
Update ....
I check all the ground and grounding points !
Make some extra ground wires direct from battery and chassis
Nothin help!
After that a friend of mine with a identical setup came to the shop we pull my emu out and try it at his car !
His emu is easily to tune no connection fails ect
So my emu swapped inside ... connection fail after rpm raisin high !
My emu was at ecumaster shop in Poland for a repair last summer ... maybee something is wrong inside ...
Any ideas
Posted: Tue Nov 01, 2016 8:28 pm
by Silas
So you already destroyed one?
Maybe you should stop tune :D
Buy a new one
Posted: Wed Nov 02, 2016 8:45 am
by Kenny123
No only the stepper motor was gone ...
Sent it back for diagnostic and get it back repaired from jakub of ecu master
