file compatibility
Posted: Wed Dec 07, 2016 7:21 am
by phill4130
hi, was wondering if anyone knows if a tune file for the black series ecu will work with the earlier model unit.
have tried to load but comes up with incorrect value errors?
Re: file compatibility
Posted: Thu Dec 08, 2016 8:36 am
they are not compatible
it would be handy to be able to save and cross load individual tables or copy/past table data but it looks like that is not possible either.
Posted: Fri Dec 09, 2016 7:33 am
by phill4130
Well that's a kick in the guts, looks like I'll be needing a new ecu then.
Posted: Fri Dec 09, 2016 4:40 pm
by roquete
why a new ecu?
Just make a tune for the one you have.
Posted: Fri Dec 09, 2016 5:06 pm
just copy all the settings over manually, even the VE table can get real close after transferring the numbers in a few key areas like idle light throttle and wide open, then just fill in the rest by eye
Posted: Fri Dec 09, 2016 5:43 pm
by phill4130
Sorry was given some wrong info, the tune file is written for the CAN ECU and I have the ECU MASTER unit with the add on CAN module.
File was loaded and it came up with "invalid value" errors about three pages of them.
Im the customer, just trying to help out the guy who is tuning it has I'm asking him to use a new system on a non common car for Australia Ford Focus ST225.
Can the tune info just be transferred over between the two different ECU's.
Your help is muchly appreciated!
Posted: Fri Dec 09, 2016 9:53 pm
by roquete
i think you have is a newer tune on old firmware.
go here:
download latest version, update firmware and try again.
Posted: Tue Dec 13, 2016 12:16 pm
For EMU black there is option to import EMU calibration files (Files / Import emu project)
