corsa E B14XER LDD BASE MAP
hello i am new here this is my first project,i have a opel corsa B14XER LDD and i want a base map to start,can anyone help me?
Re: corsa E B14XER LDD BASE MAP
not sure if dual variable cam, and drive by wire throttle, is good engine to play with as beginer... how your wiring is done? you have new loom? or some plug and play conector?
yes new loom i have install this engine in a toyota pickup and my problem is ,i dont know how to programm the throtle pedal ,the throtle body etc basicaly i need some information for programming,i am a tech electrician and this is my first programming step..
Which ecu you have? Emu or black? Im not sure how base map will help you if your loom is custom, you have to setup everything according your wiring...
Throttle body is what part number? In announcements section of thisforum is nice dbw database...
Toyota pick up????perfect!!!!
