1JZ VVTi request base map please
Posted: Thu Dec 15, 2016 10:12 am
by bwicknick
I am new to the ECU Master. Can someone help me with a base map so I can get started and get on the dyno. 1.5 JZ with GTX3076 and 800cc injectors. Not that it makes a difference as I should be able to modify the map sufficient to drive it on the dyno.
Thank you.
Re: 1JZ VVTi request base map please
Posted: Thu Dec 15, 2016 5:44 pm
by WHPZach
You'll need to check ignition configurations (number and style of coils), injector settings, vvti solenoid assignment, etc., but this map should be a workable starting point.
Posted: Fri Dec 16, 2016 9:17 pm
by ibuki56
I am interested in getting the ecu master emu for my car ( JZZ30 SOARER 1JZGTE)... My car is 100% stock and would like to know if I have to arrange settings for the car to start? And is there a large enough community to educate about to know this ecu inside and out
Posted: Wed Dec 21, 2016 10:58 pm
by bwicknick
I was in the same position. The people in this forum are very helpful. I have found all the information I needed to make my engine run. The ECU is good and very capable.
