wiring the 2jzgte vvti aristo jzs161
DET3 technical support
450franko
Post by 450franko » Fri Dec 04, 2015 4:12 am
i just receive my ecumaster tuner 3 how do i wire to my ecu i have the wiring diagram wilbo666 can somone help me
bondango
Re: wiring the 2jzgte vvti aristo jzs161
Post by bondango » Mon Dec 07, 2015 10:44 am
FIT or piggyback mode??
161 is airlow meter, so you will want to eliminate that in the end.
450franko
Post by 450franko » Tue Dec 08, 2015 2:21 am
i dont no wich mode is the best i iam new to this i dont have an airflow meter the maf i want to go map sensor Bosch 760 ev14 injector precision6266sp turbo 50 mm blow off valve mvr 44mm tial wastegate and aem water/methanol injection kit i want to make 700 hp
450franko
Post by 450franko » Tue Dec 08, 2015 2:36 am
should i wiring it up like the 1jz-gte i have the wiring of my ecu willbo666.pbworks.com 2jzgte vvti jzs 161 aristo
codeadmin
Post by codeadmin » Thu Dec 10, 2015 9:50 pm
450franko: did you make it work. I consider buying it for my own jzs161 :)
450franko
Post by 450franko » Sun Dec 13, 2015 6:15 pm
new update i wire it up 11 ground 1 12v 9 ignition in crank sensor 5 bipolor ign out crank sensor out 13 analog in #1 map sensor 17 analog out map sensor out but the red light wont go on check whit test light and power is there is the det 3 working
Kisielisodd
ECUMASTER TEAM
Post by Kisielisodd » Mon Dec 14, 2015 12:14 pm
Is this engine equipped with Air flow meter ?
450franko
Post by 450franko » Tue Dec 15, 2015 1:57 am
no i dont have the air flow meter nothing is plug in that connecter i want to go map sensor
450franko
Post by 450franko » Thu Dec 17, 2015 5:28 am
ess it work itwass the usb driver that wasnt working that why it dint connect thank to thechmaster of ecumaster
Jostar
Post by Jostar » Mon Feb 08, 2016 5:05 am
For the DET3 to work and you to make it work, YOu need the stock MAF so you can make log it and convert it to fuel map.
Alonzoszef
Post by Alonzoszef » Fri Feb 26, 2016 9:59 am
Does anyone have a wiring schamtic for a gsr engine? Basically a diagram that shows you from where the wire plugs into the ecu to where it plugs into the engine.
___
XRumer 12.0.16 + SocPlugin: the BEST program for Facebook / VK / Forums / Blogs promotion!
mihaicsv
Post by mihaicsv » Mon Jun 06, 2016 1:36 pm
450franko wrote:new update i wire it up 11 ground 1 12v 9 ignition in crank sensor 5 bipolor ign out crank sensor out 13 analog in #1 map sensor 17 analog out map sensor out but the red light wont go on check whit test light and power is there is the det 3 working
Hi,did you manage to see rpm in this config?Is IGNITION showing SYNC?Very interested as I am wiring up a DET3 to a 1jz Soarer and got stuck...thanks
