DET3 technical support
gary22b - Posts:3
ca18 det
Post
by gary22b » Thu Jun 09, 2016 7:27 pm
anybody have a base set up for a ca18 det with 800cc injectors mines just seems to flood constantly no matter how low i set it
gary22b - Posts:3
Post
by gary22b » Thu Jun 09, 2016 11:33 pm
I should have added I'm running it as fuel implant and have the ve map set to 40 low end and fuel map at 0 for full graph
gary22b - Posts:3
Post
by gary22b » Tue Jun 14, 2016 9:45 am
ok so solved that one myself , now it appears that the factory ecu is throwing a fit if the water temp is below 65c , throwing timing off wont idle etc etc , appears that the FIT system dont work that well with s13
Lolo s12 - Posts:2
Post
by Lolo s12 » Tue Jun 21, 2016 12:45 pm
Hi , what you used as ignition setup ? Thank you
