Voltage from AFM to analog input
DET3 technical support
spddm0n
Post by spddm0n » Sun Jul 24, 2016 1:05 am
I have the DET3 installed on my MR2 Turbo and I'm trying to determine how to tell the DET3 about the voltage output from this sensor (for analog input). The definition files that are pre-loaded in the software setup do not have a file for this type of AFM.
This sensor is not a liner 0-5V sensor. It is a reverse liner sensor. It is at about 4.3V when its flap is closed and about .2V when fully open. It would appear that the DET3 is getting these voltage readings correctly, but I'm not sure how, since the input scale configuration is not a reverse liner scale.
Any thoughts?
