AEM Failsafe Guage Scales Configuration
twister814
I cannot find a Scale to give the Exact Readings My AEM Failsafe guage shows. My Aem UEGO guage does show the same Readings on the DET3. Is there an update or Option to help me use the AEM Failsafe guage on the DET3 ?
Please HELP
twister814
Re: AEM Failsafe Guage Scales Configuration
I'm not finding a scales configuration for My AEM Failsafe o2 Gauge. any Information for this one ?
The DET3 Reads different than the gauge on any of scales offered form the unit
Analog scales configuration.
Read in the AEM manual to get the values
twister814
Thanks this gives me an idea where to start from with my beginner level of understanding. Hopefully this hashes out. The Newer failsafe guage offers several features as an advantage.
The Det3 has several wideband options that didn't work.
twister814
Has anyone used a Aem falsafe wideband O2 guage on the Det3 piggy back successfully. Where the unit shows the same reading as the guage ?
twister814
Can these values be entered so the Det3 reads the same ?
Have you tried something like this?
To use it, change its extension to ".def".
twister814
This will be a first for me.
Thanks alot in advance
Doable wrote:Have you tried something like this? To use it, change its extension to ".def".
twister814
I have the AEM Fail-Safe scale on analog #3 now. Just Need to check it.
twister814
I must have done something wrong. This didn't do anything.
twister814
The yellow pad lock must be why it's not working. How do I solve this I been trying so hard. I'm sure it a simple solution. Help
twister814
Doable,Doable wrote:Have you tried something like this? To use it, change its extension to ".def".
i must say i dont know how to change the extention to ".def"
any help on that id aprciate. I have been trying since you posted......lol
twister814
Thanks Doable, It seems you offer a easy suggestion it just doesn't work for some reason. By changing the extention to ."def"
Thanks again
twister814
Anyone know how to get the Det3 to read the same as on my AEM falesafe wideband guage ?
The Det3 doesnt have a Scale to match the Guage readings or they not reading the same numbers... Any Answers Please
twister814
Is this something ECU Master Tech's Must Fix ???
1. Try pasting the following quote into a text document.
2. Save it as "wideBandO2SensorAEMFailsafe.def".
3. In DET3 --> Setup --> Scales configuration, Load "wideBandO2SensorAEMFailsafe.def".
// scale definition
name = WIDE BAND AEM FAILSAFE AFR 8.5-18
linearize = 0
unit = AFR
minValue = 8.50
maxValue = 18.00
// ilosc miejsc po przecinku
precision = 1
// non linear sensors are defined by equation:
// value = coef5 * v^5 + coef4 * v^4 + coef3 * v^3 + coef2 * v^2 + coef1 * v + coef0
coef0 = 7.3125
coef1 = 2.375
coef2 = 0
coef3 = 0
coef4 = 0
coef5 = 0
twister814
Doable it seems you sent me a incomplete folder.The file you sent is invalid.
I will try to see if Doable's file work at home, subscribe for any updates.
I think I got it to work.
twister814
Any info ???
