anyone running 2jzgte automatic
DET3 technical support
mmac0405
Post by mmac0405 » Fri Feb 10, 2017 4:48 pm
hello, this is my first post and i am looking for engine managament to run on my 2jzgte automatic a340e in my sc300 looking to run id1000 injectors upgraded fuel lines and dual walbro 255s which is more then enuff my question is has anyone successfully run det3 on the automatic? i know my options for managment is limited and i know ecumaster stand alone doesnt support autos and i heard mixed reviews on aem with automatics. I live in tristate area of NY is there any tuners that tune det3? also is there base map available for my fuel setup so i can just get the car running thanks! :D :D
WHPZach
Re: anyone running 2jzgte automatic
Post by WHPZach » Fri Feb 10, 2017 6:09 pm
1000cc injectors are a no-go on a DET3 in piggyback mode, that's way too large a jump. You can run the EMU in parallel with the stock ecu, leaving the stock ecu in control of the transmission. This allows you to run any injectors you want.
If you can limit yourself to an injector in the 600-700cc range, the DET3 works fine with an auto, as it's just modifying the maf or map signal and the crank position signal. It has nothing to do with the trans.
