Det3 with 2.5 bar map sensor m50 turbo cant work map sensor
Hey guys I installed the det3 device with 2.5 bar map sensor on my 1991 m50 2.5 turbo , the problem I'm having is its running rough and it will connect to the client device and work and give signals ect but when I try and activate the map sensor in fuel implant mode it comes up with a message saying the correct software to work on fuel implant isn't installed on your device, what does this mean ? Also does anyone have any maps I could try my car has a t04 turbo with 2.8 pink injectors and spacer plate between the head and block and runs well without the piggyback on low boost with a 600 ohms resistor in the maf but over fuels massively without boost
- Kisielisodd
- ECUMASTER TEAM
Re: Det3 with 2.5 bar map sensor m50 turbo cant work map sen
http://www.ecumaster.com/en/download
Download latest software version for FIT
Open file -> upgrade firmware -> open latest firmware version -> upgrade
thanks a lot mateKisielisodd wrote:http://www.ecumaster.com/en/download
works now!!!!
thanks a lot
now what do I do to do the maf to map conversion on the car ?
also I need advice on general mapping
