Hi !
I would like to know wht'as going on, if i switch off the DET3.
Is my stock ecu working like "normal" use, or do i need to change some settings in the DET3 to create a "bypass" mode ?
The idea is to be able to switch between the stock ECU and the DET3.
Anyone can help me about this ?
cheers.
Simple question about the OFF mode
Re: Simple question about the OFF mode
if you power of the unit, then signals from sensors to the stock ecu will be lost.
You would be better having the map switch mode in DET3 used.
have a set of maps where you have adhustments amde, and one were you dont.
then just switch between the maps
Ok, so there's no "bypass" mode.
If i don't modify any parameters in the MAp 1 (for exemple), can i use thi s map like "the bypass mode" ?
felipeandrest205
You want a map with stock parameters and another map tuned.
What would i do is leave the map 1 with all the tables in 0 (no modification) and the map 2 tuned the way u want. You can do this changing the map with a switch connected on the Map Switch pin out from the det3
It's exactly what i want to do !felipeandrest205 wrote:You want a map with stock parameters and another map tuned.
So, can you confirm that if i leave all the tables in 0, it's like i'm running in stock configuration ?
