Det3 wiring
Posted: Thu Jan 28, 2016 9:29 am
by drew2322
I'm looking for a wiring diagram for 1993 Lexus sc300 2jzge turbo to go from maf to map and run a boost controller.
Re: Det3 wiring
Posted: Thu Jan 28, 2016 8:08 pm
by ihiryu
Should be pretty close to the GTE. I mean a lot of guys are using the GTE ECU on the GE now. So I would imagine it's pretty damn close, with the exception of the cam sensor.
Re: Det3 wiring
Posted: Mon Feb 08, 2016 4:45 pm
by drew2322
They use that ecu when going from distributor to coil on plug so it's a little different.
Re: Det3 wiring
Posted: Tue Feb 09, 2016 2:03 am
by ihiryu
Are you using FIT or Piggyback mode?
If you're going piggyback mode, then there's only a handful of wires you need to wire up.
Power,
Ground,
KMV/MAF sensor
And crank sensor (NE1, I'm assuming).
So if you look at how to install a SAFC (find the diagram). You will be able to find Power, Ground, and the MAF sensor. Keep in mind since you're using a KMV, you're gonna need to use the pull ups for the KMV sensor.
Re: Det3 wiring
Posted: Tue Feb 09, 2016 6:00 pm
by drew2322
I just got it so don't really know the difference in fit and the piggyback mode. I have a safc in the car now. But I wanna hook it up so its map not maf and controlling a boost controller.
Re: Det3 wiring
Posted: Tue Feb 09, 2016 6:03 pm
by drew2322
Also I have a wideband in the car what pin on the det would that go to.
Re: Det3 wiring
Posted: Tue Feb 09, 2016 9:27 pm
by 03TIBE85
If you have the DET3 with the internal 2.5BAR or 4.5BAR MAP sensor that takes up the Analog 2 input so you'll have to use Analog 3 or 4 for Wideband input. Make sure you set up the software properly for your wideband and you should be good.
Re: Det3 wiring
Posted: Tue Feb 09, 2016 11:58 pm
by drew2322
i am now trying to set up the software and am having troubles, the manual is not really user friendly in how to set things up.
Re: Det3 wiring
Posted: Fri Feb 12, 2016 5:40 pm
by Wuniek
DET3 don't have built in O2 sensor controller, so you must take if you have 0-5V signal from external controller and then load proper scale for Analog in you connected it to
drew2322 wrote:i am now trying to set up the software and am having troubles, the manual is not really user friendly in how to set things up.
