DIGITAL ECU TUNER 2
Hello, i use det 2 for Subaru, can i use det3 wiring manual for det2 connection? as deflection i plan to use separate map sensor.
Re: DIGITAL ECU TUNER 2
I understand that the pin not the same, i confused if i should use 2k ohm resistor on det2 like shown det3 manual.
