Det 3 st185 gt4
Fitted the det 3 today into my celica gt4 st185 all powers up but car will not start now I've used the wiring diagram from the website could there be a possibility it's wrong in some way or need more wires connected? I can smell fuel so I'm guessing it's not firing at all? Any help appriciated as it's currently stuck in the middle of the drive. Thanks andy
Re: Det 3 st185 gt4
Hello brotha can you tell me how do you wire it diagram. I have an mr2 turbo gen2. Mikey9517@gmail.com it will be greatly appreciated for ypur help
Re: Det 3 st185 gt4
Check the signal from the cam sensor (Ignition) is the ignition synchronised? if not it wont fire up. I've got a 3SGE which had the same problem cleaned the contacts and checked the senor gap put it back together and it synchronised and fired up first time.
