going to install it on my brother mk3 Supra, right now only intercept mode with stock maf and injectors.
Read the manual and dig internet for informations specific to 7mgte, found a thread on supramania, can someone confirm this settings for wiring, ignition and frequency are correct?
And if i've undestand correctly one workaround for fuel cut is to clamp the max frequency just below where FC occur (example, Fc at 1550hz, set max frequency 1500hz), BUT in this way there is no control for fueling over this area, every frequency above 1500hz will use table settings as 1500hz, and could be dangerous.
Thank you guys
