Is it possible in Implant mode to use Boost Control as Freaquency Out with transistor controling a valve, injectors wired in Bank Fire mode ( 18 and 20 analog out ) ?
Boost Control in Inplant mode
Hey,
Re: Boost Control in Inplant mode
everything works fine
What transistor did you use?
How did you wire it?
and dont forget to make it ON, in Boost Control parameters window, in the bottom need to click on "USE FREQUENCY OUT TO CONTROL BOOST SOLENOID"
