Hello from Greece!question about extra injectors
DET3 technical support
andreas_marg
Post by andreas_marg » Tue Oct 28, 2014 11:01 am
Hello,I am Andreas from Greece.
I want to turbocharge a N/A GDI engine and the only way to do this is using 4 extra injectors.Is there a method in DET3 that i can controll simultaneously
4 low impedance injectors .Can all be connected to one power output PWM?
Kisielisodd
ECUMASTER TEAM
Re: Hello from Greece!question about extra injectors
Post by Kisielisodd » Wed Oct 29, 2014 2:58 pm
Hi!
You should use fuel implant mode to cotroll additional injectors.
Then they will be controlled using speed density algorithm.
For lowZ injectors use 4R7 resistor in series for each injector.
You should also use both power outputs (2 inejctors per one power output)
