Wiring crank and cam sensor Hyundai Coupe RD
Posted: Wed Jan 02, 2019 1:19 pm
by mccolome
Hi there,
I own Hyundai Coupe RD MAP based Siemens ECU.
I wonder how I could wire those sensors to sync ignition properly. OEM ecu has two pins for the crank. Both sensor are three-wired.
I wonder if I should plug both crankshaft in ignition In and one wire from the camshaft (in that case, which wire of the three?) directly to the ignition out with a pull up of 2K resistance. (similar squematic as for the S14 Nissan silvia)
Thank you for your help.
Marc
