bmw e36 m52b20 turbo
Hi my name is Richard I'm from wales uk, so before buying the digital ecu tuner, I thought I'd ask if it would be suitable for my application. I'm starting with a stock m52 2.0 engine, and mounting a Subaru td04l turbo through a large fmic. I was wondering if I could carry out a Maf to map, and be able to provide enough fuel for 1/2 a bar? If it runs lean could I run a seventh injector, for fuel enrichment under boost?? Thanks in advanced rickypaulreynolds!!!
Re: bmw e36 m52b20 turbo
What's the problem with the standard injectors??
Because they are 154cc. Thats good for about 160hp on a turbocharged engine. 0.5 bar of boost is 210hp+ on pumpgas.
Was planing on some 328 injectors would they suffice pink tops?? Thanks
- ktsirigotakis
i think that 2.8 has 200cc it would be better to run m3 they are 300cc something, best for you will be 440cc and you can find them cheap!
i have map for det3 400kap m50b28 forged with gtx3076r 650cc with maf removed
Thanks for the fast reply's guys could I get a example of your wiring diagram?? And 440s shure the cosworth boys run them??
Just purchased some 440cc green giants, should I wire them in batch mode, or will the ecu auto adjust. Or will altering maf/map signal be enough?? A wiring diagram would be greatly appreciated!!
yes they are High impedance
Should I run fuel implant mode???
- ktsirigotakis
yes fit mode is the best
hello, you managed to mount the ECU?
