Some noobie issues with DET3 (HELP)
DET3 technical support
felipeandrest205
Post by felipeandrest205 » Wed Mar 11, 2015 5:07 am
Hello! After finished the wiring of my DET3 on my ST205, I have some questions
Well I set up the Ignition configuration and Fuel Tables, the car Start up and have a smooth idle.
My wideband doesnt have power and my turbo boost pressure gauge neither, what should i do? I have check over the wiring and its all correct, should have power the 2 gauges and there would be not issues with the function.
Its something between the gauges and the DET3? or they should operate fine? Anyways I have read somewhere that I should connect the wideband to the DET3... how is that? anyone can help me with the finishing instalattion?
Kisielisodd
ECUMASTER TEAM
Re: Some noobie issues with DET3 (HELP)
Post by Kisielisodd » Wed Mar 11, 2015 10:24 am
DET 3 is separate device which does not affect to other. If you don't have power supply on WBO and gauges that's mean You did something wrong in wiring.
WBO sensor can be connected to DET, but not directly. WBO sensor controller should have 0-5 volt output and this output can be connect to DET3
felipeandrest205
Post by felipeandrest205 » Thu Mar 12, 2015 7:37 pm
Ok, i've double checked the wires of the boost gauge and the wideband, and now they are runing perfectly. After the instal of the DET3 my afr is 14.7-15-5 in cold start and on idle 14.9-15.3, it seems right. Now how I connect the wideband to the DET3? I mean wich wire of the wideband should I extend to the DET3 and in wich pin of the DET3?
The wideband ist a Innovate MTX-L and the manual says
Yellow Wire (Analog Out 1): 0V = 7.35 AFR
5V= 22.39 AFR
Brown Wire (Analog Out 2): 1.1V = 14 AFR
.1V= 15AFR
felipeandrest205
Post by felipeandrest205 » Sat Mar 14, 2015 12:50 am
Despitw me, i realized that DET3 doesnt have wideband detection
ktsirigotakis
Post by ktsirigotakis » Sat Mar 14, 2015 11:15 am
Yellow wire to one avelable analog input and you choose lc-1 to see your a/f in the det3
felipeandrest205
Post by felipeandrest205 » Sat Mar 14, 2015 8:36 pm
Thanks you, now my tables read the afr
