Hi new to the forum and new to ecu master det3 product.
im building a vr6 turbo so brought this software to run it but unfortunatly i dont know how to set up basic parameters si i can get it running without the det3 attatched the car runs but connect the det3 the car wont even fire so i need to get something setup can someone help me out with this
Thanks in advance Ben
VR6 TURBO SETUP
Richardc9052
Re: VR6 TURBO SETUP
Im guessing you will be using it in the standard client and not FI?
If so, you need to go to:
Setup - Ignition configuration
Then setup the ignition mode and input type.
These settings depend on your own setup. You can search vw forums for this information as there maybe multiple setups for your engine type depending on year.
Re: VR6 TURBO SETUP
Yes i will be using as a standard setup until i send it to a professional i have setup the crank trigger etc to the right settings im getting strong input and ourput sugnals but dtil failing to start i thought this would just run off standard ecu map
Re: VR6 TURBO SETUP
Your car won't run unless your DET3 is configured correctly. Once it's configured, the car will run just as it was before you installed the DET3 until you make changes to the tables.
In order to offer help, you'll need to share the year/make/model, how your unit is wired in (factory ECU pinout would help, as well as pictures of your installation), and upload your current software configuration. With that information we'll be able to point you in the right direction.
Re: VR6 TURBO SETUP
Hi people, hoping to get some help here
Ive built a vr6 turbo (2.8 24v of a mk4 golf 4motion AUE engine code) is got bigger injectors, decompression plate, 4" maf, short runner intake manifold, 044 bosch pump, elctronic boost controller and other bits to help out on the turbo conversion, turbo is holset hx35 and is all running of a mapped standard ecu.
I have purchased the det 3 joping i can properly get the car mapped but i havent to lucky to find the people to do so.
I need some help with the wiring if anyone on here has got the diagrams for this engine.. i would be very much appreciated
Turno
Turno
