ECU cannot connect
Hello everyone. I still have problems with DET3. I have a bmw e36 engine m52b25. I connected the unit says the scheme for BMW. if I put the pins used to ground the unit it does not turn on. In fact the moment I keep them loose. Another problem, the computer feels that there is a control unit attached, but when I open the client or the fuel implant appears that the unit is not connected. can you help me? thank you
Re: ECU cannot connect
what Windows are you using? have you be sure DET3 recognized in your Microsoft windows System Properties? Any COM Port conflict ?
Be sure to crimp terminals in DET3 nice and tight, check on terminal 1 & 11 on your DET3 with volt meter to make sure you have good IG+ and ground (nominal battery voltage). Have you following wiring diagram as http://ecumaster.com/pobierz/det3/DET3_ ... agrams.pdf ?
I tried it with win 7 and win in the computer 8. says the device is properly connected . I also tried to change usb cable but nothing
