I 'm going to buy a DET3 but I have not understood the wiring diagram yet
the engine is 1990 stock 7M
I am confused with some wires
DET3: ------> (Symbol) (Terminal name) 7M ECU
Pin 1 (+12V)---------->(+B) (EFI Main Relay)
Pin 2
Pin 3
Pin 4
Pin 5
Pin 6(Ignition Out)---->(NE) (Cam Position Sensor)
Pin 7(Frequency Out)->(KS) (Air Flow Meter)
Pin 8(Pullup)------2.4 kΩ + Pin 10(Frequency In) ------->(KS)(Air Flow Meter) ??I am confused
Pin 9(Ignition In)------> 7M ecu pins are IGNITER: IGT or IGDA or IGDB or IGF?????
Pin 11(Ground)-------->(E01)(Power ground)
Pin 12
Pin 13
Pin 14
Pin 15
Pin 16
Pin 17
Pin 18
Pin 19
Pin 20
Pin 7 , pin 8 and pin 10 go together to KS??
Could you help me to finish wiring diagram please?
