Hey guys quick question.
Im getting a reading of 1.144 volts at analog input #2 with nothing attached. Ive tried disabling the input and grounding it and the voltage remains the same. Also if I put 5 volts to the input nothing changes either. Im using input 2 to activate launch control while input 1 is my factory map sensor, 3 is my wideband and 4 is the built in map sensor. How can I fix input 2 to use as a switch?
Unknown voltage at analog input
Re: Unknown voltage at analog input
do you have DET3 with build in MAP sensor? if yes sensor is connected inside device to analog#2
Supra Sundays wrote:Hey guys quick question.
