DET3 for Additional Injectors ?
DET3 technical support
golf_g_turbo
Post by golf_g_turbo » Sun Mar 06, 2016 5:09 pm
have anyone Experience with the DET3 to run it as Additional Injector Controller ?
So i will do it on a TFSI Engine to run four Additional Injectors. The Problem from all Aftermarket Controller is the pick up from the Rev Signal. DET3 is the only one with a way without Tach Adapter or other Things by TFSI Engines or other new Fuel Controll Systems.
My plan is to Disable all Corrections like Warmup etc.... to run the Stock Fuel System without Problems and made the rest with Fuelcut Option over Pressure. For example Fuel Above 1.0Bar. DET3 are only Active over this Pressure.
Great Feature for the DET3 would be a Additional Injector Controll Setup with it. The Features at Time are Great but this is the Next for it i think. I Hope the EMU Team can give a Feedback about it.
