Hi
When you have wired the unti up and installed the software.
What is the next step? Do you start by logging and build from there?
Can you connect a wideband map sensor to this?
Thanks in adwance
A few questions about the product
Re: A few questions about the product
Hi!
When you connect DET3 in piggyback mode the car should work as without devices (all tables are 0).
Now you can modify fuel dose by altering Fuel table (positive values increase fuel dose, negative decreases).
The same with igbition angle, positive values advance ignition negative retard.
You can use any free analog input to connect output from WBO controller. DET3 cannot work with wideband lambda sensor without external controller.
Thanks for the answer.
So when the ecu is connected and no changes has been made I can use the car normally?
Then maybe do a logging session and tune accordingly. Is there any form of autotune available?
Is the Fuel Implant for additional injectors or does it serve other purposes.
Is it needed to add an additional map/maf sensor or can the oem one be used
Where can I get a wbo controller? is this ok :
http://www.ebay.com/itm/AEM-30-4100-DIG ... fb&vxp=mtr
Can I put in safety features for instance knock sensors
