RB25 STAGEA RPM TO LOW
DET3 technical support
centoproject
Post by centoproject » Sun Sep 13, 2015 10:33 pm
hello after fitting the det3 into my nissan stagea it seams that the rpm readings are to low no matter what ignition mode i select unless I'm doing something wrong the car dose start although won't rev above 3k not sure what I'm doing wrong hopefully someone can help i can upload screen shots if thats helps
also is there some sort of basemap ? for the rb25
regards chris
ihiryu
Re: RB25 STAGEA RPM TO LOW
Post by ihiryu » Thu Sep 17, 2015 1:32 am
Chris,
I don't know if your ECU pin out is any different from any RB skyline.
I have a R32 GTST, I wired up exactly how the wiring manual shows, and followed the configuration (Configuration 7 on the bottom of the wiring manual), and I have no issues. Car runs like how it did stock.
The only thing I can think of, would be the MAF wiring (13, and 17 on the DET3), or the CAS wiring (6, and 8+9). I didn't even solder mine, I just used quality electric tape.
Once I configured mine, I left it alone, and the car runs like stock.
