There is a new FIT firmware (1.44) with injector opening bug fixed.
This bug causes a hickups (especialy on low engine load)
The new software can be downloaded here:
http://ecumaster.com/testVersions.html
NEW FIT Firmwate
Re: NEW FIT Firmwate
Thanks for the update !
Can i suggest something : it could be nice, if the color of the window border (for exemple) change, when the switch is used to switch between map 1 or map 0
Actually, the indication of map switch is not very clear.
Jean Niemi
- Contact:
Jakub,
Are you sure the link is to the new software? After installing it, it still shows 1.42 in the software. Also the random hickups at idle are the same as earlier.
Or, am I doing something incorrectly
