Device Download - Analog Output Step (Bug?)
Posted: Fri Dec 09, 2016 3:47 am
I'm not sure if this bug annoys anyone else but I've had an issue with it a few times now.
When connecting to the DET3 it downloads the Map from the device but doesn't download the Analog Output Step Voltage setting - it defaults to 0.049v
For instance.
Create a tune with a 0.98v step, make it permanent on the device.
Disconnect and reconnect to device - download map.
Save map to file and it's now saved your tune with a 0.049 step.
Upload that file and your car now runs lean.
I haven't tested it fully but I suspect it also effects the Setup Tables as well. Scalings are understandable as they are user configurable.
For instance.
