I just tested my EMU with an M50B25 BMW inline 6 cylinder Motor without Vanos.
I use the EMU standalone with FW 1.100
I had to adjust the settings for the Crank an Camshaft sensors, but finally it synchronised and i got sparks
I want to run full sequential, COPs and injectors.
The spark order is 1 - 5 - 3 - 6 - 2 - 4
But I have trouble to keep it starting and running. There's something wrong with the injector settings i guess.
For the injectors to squrit to a closed inlet valve I set the order as in the picture attached....
The inlet valves open arround 300°-240° BTDC
So with this injector phase it should squirt like this:
IGN: 1 - 5 - 3 - 6 - 2 - 4
INJ: 6 - 2 - 4 - 1 - 5 - 3
right?
But somehow the motor only starts with the option "batch all injectors" enabled. And then it runs very bad, stumbles and after few seconds it's off again.
Where is my mistake?
