Thx for the video's. They are great.
Kopie is also an Dutch word , i am from Antwerp Belgium.
It is a pity that there is no injector phasing/rpm table in the emu .Only fixed.
As on high rpm and high boost the phasing should be quite different to low revs and idle.
You can see also higher up on the table from original marelli ecu.
Sho what can you advice ? Directly after TBC before exhaust stroke ?
How to set up in ecu ?
I have wasted spark and set up ignition 2121 output to ignition event.( switched output from picture )
