Kadett E C20LET
Posted: Sun Feb 14, 2016 12:15 pm
by c-coupedriver
we start running the Kadett Yeasterday for the first Time.
20160213_132248 by
Andreas Reichel, auf Flickr
The Car is running quite well with a Base Map.
Now we have to Tune it with Autotune.
only one Question:
How to use the Vehicle Speed ?
there are tree Wires on the Gearbox Sensor
brown, black,blue/red
I mesure a Signal on the black wire
How to adjust the VSS in the EMU and
Do I need a pullup ore anyelse ?
Regards,
Andreas
Re: Kadett E C20LET
Posted: Sun Feb 14, 2016 3:27 pm
by kris4cars
brown - ground
black - +12
blue/red - signal
Pull-up pin emu to 12v or 5v
Re: Kadett E C20LET
Posted: Sun Feb 14, 2016 8:03 pm
by c-coupedriver
Thank you for your fast answer.
Like this:
is this a Vr or Hall-Sensor ?
Is the original Tacho in the LCD Display still working when i put into a Pullup?
regards,
Andreas.
Re: Kadett E C20LET
Posted: Mon Feb 15, 2016 8:55 am
by kris4cars
LCD it has an internal pull-up.
This is hall or optical.
Output its open collector.
Turn on pull-up in emu.
Re: Kadett E C20LET
Posted: Tue Feb 16, 2016 7:48 pm
by c-coupedriver
only enable Pullup in Emu is not working. I tried also different Trigger Edges.
Which kind of restitor should I choose for the external Pullup ?
is 1K Ohm ok ?
regards,
andreas
Re: Kadett E C20LET
Posted: Wed Feb 17, 2016 1:31 pm
by kris4cars
strange...
should work even without pull-up.
digital show speed?
maybe wrong wire?
Re: Kadett E C20LET
Posted: Sun Aug 28, 2016 3:42 pm
by turbogsi
hi,
have you find out how to configure the vss?
Re: Kadett E C20LET
Posted: Tue Aug 30, 2016 12:29 pm
by c-coupedriver
turbogsi wrote:hi,
no we haven“t
we drive without VSS.
I gues we should only use EMU on the Sensor and not both, EMU and LCD Display.
Re: Kadett E C20LET
Posted: Wed Sep 14, 2016 9:03 am
by kris4cars
Now i see problem
SIGNAL ITS ON BLU/RED WIRE
