Kawasaki GPz 750 Turbo
Hello
Just started setting up the EMU ECU to run my GPz 750 Turbo Drag Bike.
Its bored out to 810cc with the standard ECU and a power commander.
Todate I have manage to get 272 RWHP and a top speed of 201 MPH speed run.
I am hoping to use a bigger turbo and the EMU ECU to better control all the funtions.
I have a question to start with:
I am using four LS-2 coils with a built in amplifier. I have the ECU set for this type of coil however the coil needs 5V to trigger it.
Will the ECU be able to do this?
This the link to the type and contect of the coil:
http://www.jfetech.nl/LS2-Coil
Re: Kawasaki GPz 750 Turbo
Just a couple of Pic to be going on with.
EMU will work fine with this coils. Wiring diagram in attachment.
- LS2 coils.pdf
- (108.51KiB)Downloaded 181 times
Hello
Thank you so much for the fast response.
I guess other people wanted it too as it has been downloaded 9 times before I got to it.
And my EMU unit has just turn up in the post... Just get better.
Play time.
Play time.
Have a nice play
We want to make this forum as a knowledge base for other people.
How are you getting on with the bike ? hope its going well
Hello
Sorry no reply been out of it for a while. Just starting to sort things out in the workshop so hopefully back on the horse soon...
Please keep us posted, the project is very interresting
Hello
Just started to get into the ECU and have an "on the bench" test rig to allow me to make some adjustments without an engine running.
I'm using the Graph Log 1 and see the sample rate is 0.1 of a second. Its there a way to change the sample rate to 0.01 of a second?
Tack1000
Tack1000
No way. The sampling resolution is 20Hz
Hello
Thank you for your reply.
I'm sorry I was not clear enough, I meant the data shown is in 0.1 seconds. Not the actual sample rate.
This excel file shows the 0.1 cell change.
This screen capture shows the graph at 4 minutes and 24 then 25 seconds and so on. The light coloured lines show the divisions in 0.1 of a second.
As you can see from the excel file the time stamp is 0.1 second. I was asking if this could be increased to 0.01 second.
However as you have said the sample rate is 20hz (0.05) then that's the best data shown rate it could be.
So I ask can the "shown rate" be 0.05 to match the "sample rate"?
Thanks Tack1000
Thanks Tack1000
After separating out the Data it's even more clear what I mean.
You can clearly see the time is in 0.1 seconds.
